Sponsored by: CARiD
belt squeek help
Old May 26, 2009 | 10:25 PM
SSickLS1's Avatar
Gatorback squealed just as bad as the Gates if not worse!! Belt dressing is a zip tie bandaid style fix. After a factory GM belt i could only hear the lifters tap tap tickin - no belt dressing necessary.
Old May 27, 2009 | 01:24 AM
WhiteRhino's Avatar
Just pull the belt off and start the car, to see if it's the belts or pullies. Also, where are you getting grease from the pullies? There is no grease. They are sealed bearings. You dont use grease of any kind when putting on the pullies.
Old May 27, 2009 | 09:48 AM
bballr4567's Avatar
Yes, they are "sealed" but they arent. You CAN repack them. I did and I killed a high pitch while that I had until the car was warmed up.
Check out the link that I posted a few posts up.
Old May 27, 2009 | 11:54 PM
WhiteRhino's Avatar
Bandaid fix. Just because you can, doesn't mean you should. They are a sealed setup, period. Not trying to argue. Just saying if you do try to repack a sealed bearing, it should be temopary.
Old May 28, 2009 | 12:02 AM
bballr4567's Avatar
The pulleys are great EXCEPT for the grease. It burns off because its cheap and then the bearings get destroyed and you need a new pulley. That is money in the pulley makers pocket. You repack it with good grease and itll last for 4 times as long. Ill keep repacking mine with good grease if it saves me close to $100 every two years. Doesnt sound like much but itll add up if you own a car for 8 years.
