Not your normal A/C problem
Things I have done are: check coolant level, replaced radiator(small crack), Check level again, replace wire and plug to coolant temp sensor (when you touched the wire/connector idle would drop, has since fixed that problem), fans are all working(sometimes will run at 1st start up of day, not sure why, maybe related) if I unplug the pressure sensor on a/c line, compressor usually kicks on, then turns off. Swapped relays around everything still works as should. I had system evac and refilled with dye and no leaks found yet. Pressures read
100 low side static
91 high side static
29-30 low side comp running
148-175 high side running (1st check 175 then checked again at home with same gauges 148, I think I had the valve open on both and let it equalize, low side shot up)
temp on dash guage 210 constant(I know, not accurate)
I have researched this for about 2 weeks now (bought car off of member here with blown motor and purchased long block from him and had him rebuild motor and install) A/c has not worked normally since purchase.
things I know I need to look at are the a/c pressure switch and coolant temp sensor. I hope I didn't miss anything. Sorry so long but could someone maybe point me in the right direction. Thanks
100 low side static
91 high side static
Fix it.
Coolant temp sensor has nothing to do with the A/C system.
But yes, the coolant temp sensor can cause the fans to go on and off and freak out if its going bad. But as far as I know, it has no ties with the a/c compressor.
Change both.
