Sponsored by: CARiD
Leaking transmission fluid
Old May 20, 2009 | 06:58 PM
lookingforws6's Avatar
Default Leaking transmission fluid
I went to the drags a few weeks ago and then my car sat in the garage for about a week. When I went out there to put some new oxygen sensors in I noticed a small puddle on the floor. At first I thought the front plate on the transmission was cracked (the part btw the tranny case and the bellhousing) but after cleaning it with brake cleaner and letting it sit I found that it was coming from the seam btw the front plate/ adapter and the bellhousing (right on the botton, not on the sides). From what I can guess so far by looking through threads I think it might be the input shaft seal on the transmission. Does that sound right to anyone? I tightened the bolts to the bellhousing slighty and it stopped leaking (so far) but I don't think there should be any fluid in there at all (correct me if I am wrong) and it's just building up in there. I'm probably going to pull the transmission soon but wanted opinions from you pros on here first. Thanks in advance for any help.
Old May 21, 2009 | 10:30 PM
Bueller?....anyone?...anyone?....
Old May 26, 2009 | 11:03 PM
BTW is a M6 transmission.
