LT1 Belt tensioner replacement
You should be able to get one at and auto parts store. As for replacing it you will need to take the belt off its a 13mm in the middle of the tensioner pulley, and then there are two bolts on the tensioner i believe they are 10mm. It is easiest to do it from below.
