Sponsored by: CARiD
installing a front parking light bulb
Old Jun 10, 2009 | 09:01 AM
omcar's Avatar
Default installing a front parking light bulb
I have the bulb but don't know how to install it...car is a '01 formula and my driver side signal light/parking lamp is out..thanks
Old Jun 10, 2009 | 05:24 PM
StuntmanMike's Avatar
I haven't changed that bulb yet, but I have changed the fog light. What I do is flip up the head lights, and just reach my arm down there while the lights are up. Very easy to get at the bulb that way. I imagine it'd be the same thing for the parking light, since it's right next to the fog.
Old Jun 10, 2009 | 08:29 PM
slayerized6's Avatar
if you go underneath your car, infront of the front wheel well is a access door in the mud flap (2 10mm bolts). unbolt the 2 bolts, and the parking light is right there. you can get it on your back without the car being jacked up, but i usually just lift the front corner and its 10x easier
i doubt you can get it from the top through the headlights. foglights yes, parking lamps no
Old Jun 11, 2009 | 01:37 AM
iowackers's Avatar
I just changed both of mine on my '98 TA. I went through the headlights. I just turned them on, removed the 3 screws that hold the plastic shroud around the headlights on, pulled that off and you can reach right in and change the parking/turn signal bulbs. Very easy.
Old Jun 11, 2009 | 02:12 PM
Daredevil_TA's Avatar
I think the flap underneath is the easiest way-However, dont be surprised if changing the bulb doesn't fix the problem. Pull the socket out of the housing and take out the old bulb and see if any water comes out or has corrosion built up in it. If yes then you'll need to splice in a new socket. Common problem on Firebirds, especially on the D/S-Pm me if you have any more questions
Old Jun 11, 2009 | 06:09 PM
Adam2001WS6's Avatar
+1
If replacing the bulb doesn't fix the problem, I have a writeup that would be very beneficial to you.
Old Jun 12, 2009 | 07:45 AM
omcar's Avatar
Well, I just went out to the garage flipped the headlights up and went in through the top. With a flashlight I saw the back of the lamp turned it and it came out and then I pulled the bulb out, replaced it and shoved the whole thing back in with a twist.
Old Jun 12, 2009 | 10:15 AM
Did the replacement bulb solve the problem?
Old Jun 12, 2009 | 10:31 AM
SLPGTP's Avatar
I'm too lazy to use the access door. lol I just stick my hand in the vent below it.
Old Jun 12, 2009 | 02:20 PM
omcar's Avatar
yup..bulb solved the deal
