Sponsored by: CARiD
Won't start .. click noise.
Old Jun 17, 2009 | 01:47 PM
1badWS6's Avatar
Default Won't start .. click noise.
Car is an '01 WS6.
Every so often I get in and try and start the car, and the only thing I hear is a click from what sounds like the starter. When I'm turning the key it clicks and the gauges and everything go down as if the car was off. It takes a couple times of this for it to actual go ahead and crank/start. Any ideas? I'm thinking something with the battery maybe? But, it's a brand new Optima Red Top.
Old Jun 17, 2009 | 02:10 PM
01CaMMMaro's Avatar
could be alternator, you can take your battery and alternator to be checked at any local AP store.
Old Jun 17, 2009 | 02:19 PM
1badWS6's Avatar
I might do that. I got the battery less than a year ago so that would suck big time if it was the battery...
Old Jun 17, 2009 | 03:15 PM
2001NBMZ28's Avatar
Check the terminals/have the battery load tested first, just to eliminate them as the problem. Most batteries have a free replacement warranty for 36 months. Make sure it's at least a 690 CCA.
Old Jun 17, 2009 | 06:22 PM
1badWS6's Avatar
Will do! Thanks for the help. I'm hoping it isn't anything more serious though.
Old Jun 17, 2009 | 07:02 PM
1Loudz28's Avatar
sounds like your battery is drained from your alternator not working 100%
Old Jun 18, 2009 | 09:38 AM
1badWS6's Avatar
Might have to replace both of them ... That's what I was kinda thinking last night.
Old Jun 18, 2009 | 09:54 AM
CRAWLIN's Avatar
If battery and alternator checks out... check your starter relay....
Old Jun 18, 2009 | 01:53 PM
1badWS6's Avatar
Where might that be located?
Old Jun 18, 2009 | 03:16 PM
john563's Avatar
mine did that..Would not crank just a click,but would start after a couple of times..it ende up being my starter relay.Replaced and now it fires up every time
Old Jun 18, 2009 | 08:42 PM
CRAWLIN's Avatar
Starter relay is located on drivers side in the fuse box ... it will be labeled...
Old Jun 19, 2009 | 09:56 AM
1badWS6's Avatar
Yeah I'll have to check that out once it gives me 5 minutes of no rain. Sounds the exact same as mine john. I'm gonna check that out thanks guys!
Old Jun 19, 2009 | 09:15 PM
Darksol's Avatar
The click sound could be a bad connection at the battery itself. The connection may not be strong enough to allow the amps drawn by the starter to be pulled. Also I believe that optima was bought out and the newer ones are not as good as they once were.
Old Jun 19, 2009 | 11:02 PM
1badWS6's Avatar
Still haven't gotten a chance to get out there. It rained some more and just quit now so I'm gonna try and get out there tomorrow morning.
Old Jun 20, 2009 | 12:05 PM
SnakeStomper's Avatar
This started happening to me too, thanks for the suggestions guys. I'm going to check this out.
Old Jun 21, 2009 | 08:02 PM
BAD2000TA's Avatar
Had the same problem with an Optima Red Top. The battery just wasn't that "great" and eventually just got weaker. Sometimes would start, other times very slow. Replaced with Sears' latest best battery (Die Hard Platinum?) and haven't had any issues since.
I've just never had much luck with the Red Top batteries.
Old Jun 21, 2009 | 08:23 PM
FactoryZ28's Avatar
switch the ignition relay as well, just in case its that.
Old Jun 22, 2009 | 12:40 AM
Arc00TA's Avatar
Mine does this about one a week, and I ALWAYS find the negative battery terminal has come loose. Just wiggling it a bit makes it fire right up. I thought my battery died several times and tried to jump it with no luck until I figured this out.
Old Jun 22, 2009 | 11:37 AM
mrmahone's Avatar
I had this problem a while back, it would click and the gauges would do the same thing, if I wiggled the positive battery cable it'd work good again for a while..... turned out to be my positive battery cable, don't ask how, but the connection that leads away from the battery and down near the starter went bad, looked like it had some corrosion on it. Got a new positive cable, put it on and never had the problem again.
Old Jun 23, 2009 | 08:45 PM
1badWS6's Avatar
I'm gonna have to do some more searching. I tried the starter relay and that didn't work. I'm gonna look into the terminals tomorrow but I just replaced one of them last weekend so I know it isn't that one.
