Sponsored by: CARiD
Way to clean plug wiere
Old Jul 10, 2009 | 09:25 PM
hitmanws6's Avatar
Default Way to clean plug wiere
Is there a way to clean the inside of a plug wire safely?
Old Jul 10, 2009 | 11:57 PM
firetpi's Avatar
Do you mean clean the terminal ends?
If so the only thing i can really think off the top of my head would be a very small wire brush. Although if your wires are rusted/corroded at the cost of a new set i would just replace them.
Old Jul 11, 2009 | 12:02 AM
hitmanws6's Avatar
no i mean a spark plug wire. the wires are only a few months old with only a few K on them. Im throwing a misfire code in cylinder 8. The plug was changed yesterday, and the opti is fine. So the only thing i can think of is a dirty plug wire
Old Jul 11, 2009 | 12:06 AM
firetpi's Avatar
Have you ohm tested the Wire? And inspected that it wasn't burned up or cracked?
I wonder if perhaps a fuel related issue may be the culprit, perhaps a clogged injector?
Old Jul 11, 2009 | 12:09 AM
hitmanws6's Avatar
the wire is fine, so its either dirty or my injector is the problem
Old Jul 11, 2009 | 12:12 AM
firetpi's Avatar
Thats the line of thought i would go with if all said ignition components were working properly.
Perhaps you have a stuck up injector. How dos the plug look after running?
Old Jul 11, 2009 | 12:15 AM
hitmanws6's Avatar
plug looks fine. ill go buy some injector cleaner tomorrow see if that helps
