quick question about radiator
my question is, is it normal for the coolant to be boiling like that or is it possible that my radiator fan is broken? is there anyway to check if the fan is broken?
thanks
i bet florida is not as hot as oklahoma tho
if you have a 50/50 mix of water & antifreeze, the boiling point is not until 265 degrees F if the system is under pressure to 15 psi.
if it is getting that hot, over 240F, you would definitely notice your temperature gauge over to the far right.
What you might be hearing is the system (radiator) relieving pressure into the overflow tank having a gurgling sound which may be normal. Otherwise, the simplest thing to do is replace your radiator cap, I think it's an 18psi cap, and make sure the gasket on it is good and the radiator neck it seals on is clean. And make sure coolant is topped off in the radiator along with having the correct amount in the overflow tank shown by the overflow tank dipstick.
And you said last week you flushed the coolant,
either you have some air in the system which hasn't worked its way out so every time the car is cold open the radiator cap and keep topping off the radiator and check the overflow tank and make sure it has enough. After a few cycles the air will work its way out. The other is when you flushed the system you had water left in the system when you added your 50/50 coolant mix which may have resulted in a 40/60 or 30/70 antifreeze to water ratio which will drastically lower the boiling point, in which case you can drain the radiator a little then add straight antifreeze to try to get it back to 50/50 or 60/40... higher antifreeze ratio increases the boiling point but don't go over 70/30 antifreeze to water. See if you can find an antifreeze tester at the parts store, that'll tell you what the freeze point is which you can determine what ratio antifreeze to water you have.
thanks
and yes i always use antifreeze, and couple times if it was gurgling(boiling sounds) there's coolant overflowing from my expansion tank(from the top)
I don't care what anyone tells you boiling after shutting off is NOT normal!
can you explain how the water pump gasket leaking caused the boiling sound?
1) NOT boiling http://en.wikipedia.org/wiki/Boiling
Boiling is water turning to a gas and escaping from the system. IF your coolant is the right mix and IF your temperature gauge is not lying to you, then you just have fresh air getting in to the system. The coolant system on these cars is a sealed system and the overflow tank maintains a siphon with the system and transfers coolant back and forth to regulate pressure in the radiator as coolant expands/contracts. If you have a leaking gasket or a bad radiator cap that doesn't seal, then you can get air in to the system. (Especially when you turn the engine off, which turns the water pump/pressure off, and the coolant starts to contract in the radiator.)
2) IS boiling
IF your system is sealed properly and IF your temperature gauge is not lying to you, then your coolant to water ratio is off. You should be able to purchase a special hydrometer http://en.wikipedia.org/wiki/Hydrometer from your local auto parts store to test this.
So... there are a number of causes that could lead to the two instances above. I'd suggest going in this order due to probability of cause and the cost involved:
- Buy a new radiator cap (Be sure to get a GM/AC Delco cap and not an aftermarket cap from your local auto parts store. The GM cap has a special pressure relief that will prevent the plastic parts of your radiator from imploding in the event your overflow siphon gets stopped up. The aftermarket caps do not have this feature.)
- Steal your Mom's meat thermometer and test the temperature of your coolant to see if your temp sensor is bad. (Keep in mind that the coolant at the radiator will be a lower temperature than at the sensor closer to the engine.)
- Buy a hydrometer and test your coolant or take it to a Jiffy Lube, where they will probably do it for free! (Maybe you do this first, if you really feel like things are boiling.)
- Check the siphon on your overflow tank and make sure everything flows properly (and does not leak) between your tank and the radiator.
- Check your water pump and thermostat gaskets.
- Find religion and then explore your head gaskets.
If you have coolant leaving the system, you will have air in its place. HOW does that air get in there to take its place....through that same leaky gasket or hole in a hose, or whatever. It gets sucked in when it cools. That air is what allows the coolant to boil over by lowering the boiling point of the coolant.
You're coolant can still show full, depending on where that air bubble comes to rest in the system.
----Get a new radiator cap
----If that doesn't do it, get a leakdown check to see if you have blown head gasket(s).
Until you do these two things, you will most likely not find the problem.
