Sponsored by: CARiD
Cat is Hitting Floorboard...what to do?
Old Jul 11, 2009 | 08:43 PM
AgentLS1Z's Avatar
Default Cat is Hitting Floorboard...what to do?
Hey,
I just had High Flow Cats welded into my ORY...the Driver side cat is hitting and rubbing against the floorboard during acceleration. I jammed some heater hose between the cat and floorboard and it seemed like it was helping a bit but its still thumping around. What should I do? Get it welded in a different location?
Old Jul 11, 2009 | 08:59 PM
Danny2tek's Avatar
Originally Posted by AgentLS1Z
Hey,
maybe moving it a little back?
Old Jul 12, 2009 | 02:07 PM
taws6m6's Avatar
woo him out with a little cat nip lol some of the sponsers make a little hanger for the y pipe to keep it from hitting the floor, that may help. Your mounts may be wore out also. The heater hose with a clamp ran through it works good too
Old Jul 13, 2009 | 09:00 PM
stilltime's Avatar
What's a cat?
Your mods make it look like you don't need to pass emissions, I'd say sell the cats but that's just my $.02
Old Jul 13, 2009 | 09:09 PM
AgentLS1Z's Avatar
I'm tired of the gas smell so i got high flow cats welded on. they also make the car a lot quieter. the driver side cat is only 1/2 inch from the floorboard. when i accelerate i guess the y pipe twists and hits the floorboard.
Old Jul 13, 2009 | 10:12 PM
Joshiedoom's Avatar
Poly mounts
Old Jul 15, 2009 | 09:36 AM
Slowmaro305's Avatar
Does the heater hose withstand the heat or do you wrap the pipe with some sort of header wrap first?
Old Jul 16, 2009 | 10:33 PM
jeremyb4c's Avatar
i would check your motor and tranny mounts first
Old Jul 17, 2009 | 06:50 AM
Ironxcross's Avatar
+3 on the mounts. get poly motor mounts
Old Jul 17, 2009 | 06:59 AM
RsSean's Avatar
If it is not your mounts, there is a clamp per say that goes around the pipe and holds the pipe down under acceleration. I have one on my car and it changed Y-pipe from clunking on the driver floor board. There is a real name for, but I will have to look for it.
Here you go took a few minutes
http://www.mufflex-performance.com/m...tegory_Code=FZ
Old Jul 17, 2009 | 07:32 AM
jmill96Z's Avatar
Floorboard + BFH =
Old Jul 17, 2009 | 07:36 AM
ssZL402's Avatar
take the cats off if you cant stand that beautiful smell u shouldnt own the car. ps w/ur mods if the smell is that strong ur prob running a bit rich dont be cheap mail order tunes are a waste of time do it right or dont do it
By Brett Foote | 2026-06-04 05:00:17
