oil and turn signal question.
What oil do you guys use? cammed, 50k miles ls1.
My right turn signal sticks. When I click it up when I wanna turn right, the light just stays on... doesn't blink. The rear lights light up and so does the front, they just don't blink.... any help?
Does the right daytime running lamp run when the headlights are turned off? I was confused the first time my light burnt out. Its a double filament, the daytime running light and the turn signal are on one filament and the emergency flashers and the light when the headlights are turned on are on the second filament...might try to just replace the front turn signal light and see if you still have a problem. I dont think its your flasher unit since your left side is working normal.
Oh and I use Castrol syntec European formula and the car is a DD with 101000 miles
