Sponsored by: CARiD
AC wont come on at idle
Old Jul 22, 2009 | 09:54 AM
6.0vortecchevy's Avatar
Default AC wont come on at idle
Well im from over at ls1trucks but no one there could seem to help me, so ill give it a shot here. My problem is when ever I come to an idle my ac shuts off. i checked the pressure and everything checks fine there and all the connections are good. The only way i can make the AC run at idle is if i go into real time tuning and lock the ac compressor in manualy. Any thoughts guys. O and my idle is set at around 700.
Old Jul 22, 2009 | 11:25 AM
fleetmgr's Avatar
When you say it won't come on, do you mean that the compressor clutch will not engage or something else?
Old Jul 22, 2009 | 11:37 AM
yea the clutch disengages at idle. but once i get the rpm's above 1k it will engage agian.
Old Jul 22, 2009 | 11:42 AM
fleetmgr's Avatar
Take the clutch straight to the battery, and see how it behaves then. If it still won't engage, make sure the battery is good. If it is, replace the clutch.
Also, check your alternator output.
Old Jul 22, 2009 | 11:45 AM
well is it the same if i can lock it with efi live. since it does lock when i do it with the tuner.
Old Jul 22, 2009 | 11:49 AM
fleetmgr's Avatar
HMMM! Well, you wouldn't think it would make a difference, but I'd check all the same just to eliminate possibilities at this point.
Old Jul 22, 2009 | 11:50 AM
so what your say is run a wire from the compressor to the battier and see if the compressor kick on then.
Old Jul 22, 2009 | 11:55 AM
fleetmgr's Avatar
You got it, 1 to pos and 1 to neg, doesn't matter which way they go.
Old Jul 22, 2009 | 11:57 AM
Now if it does work, can i keep it that way or is this just for testing.
Old Jul 22, 2009 | 11:58 AM
fleetmgr's Avatar
Testing only!!!
Old Jul 22, 2009 | 12:00 PM
Thats what i thought lol. ill go do that right quik.
Old Jul 22, 2009 | 12:14 PM
okso the compresser kick on when i hot wire it.
Old Jul 22, 2009 | 12:18 PM
fleetmgr's Avatar
OK, now that you've had to disconnect and reconnect the compressor, what's it do when you try to operate normally - same thing?
Old Jul 22, 2009 | 12:20 PM
yup right when i put it in back the regular way it went back to what it always did.
Old Jul 22, 2009 | 12:33 PM
fleetmgr's Avatar
OK...I see in your OP that you've been inside the computer. Do you have a tune in it? If so, what happens when you go back to stock?
Also, need some vehicle specifics.
Old Jul 22, 2009 | 12:36 PM
well its a 00 2500 6.0 chevy and if i went back to the stock tune it bearly runs. And does the same thing.
Old Jul 22, 2009 | 12:47 PM
fleetmgr's Avatar
Well, then I'd suspect a wiring issue in the dash. Something making intermittent contact, like maybe the blower switch. Possibly a wire touching something, and vibrations at speed making it not touch...something like that.
Old Jul 22, 2009 | 01:17 PM
well when im driving the ac works perfect.
