Sponsored by: CARiD
engine removal?
Old Nov 19, 2003 | 11:47 AM
tony124's Avatar
Default engine removal?
looking for some detailed engine removal and install instructions, gotta rebuild the lower end. Already tried ls1howto.com. Thanks
Old Nov 19, 2003 | 12:39 PM
onyxxtreme's Avatar
just do a search on here, thats what i did
I havent seen any how-to's on taking out the engine, but I did follow ls1howto.com's instructions on the "cam/head swap" page on some parts of the removal process
btw, are you gonna remove the engine from the top or drop the subframe?
Old Nov 19, 2003 | 12:57 PM
tony124's Avatar
I'm planning on dropping it out the bottom, ive heard its easier.
Old Nov 19, 2003 | 02:16 PM
onehardmaro's Avatar
Diffently take it out the bottom.
Remove air intake, fans, and radiator, disconnect brake lines from pump(only two), disconnect slave or shift cable if automatic. DIsconnect two plugs for pcm and plugs on the fender well. Put rear on ramps and lift front as high as the floor jacks hold.
Take two hand jacks and position on cradle. Another one on the crossmember. Take out crossmember bolts, the six cradle bolts and the six top strut bolts. Now its ready to start being lowered. Once its lowered just role it out. I used 6x6 on the jacks, they helped alot. Dont for get to disconnect the battery before doing any of this. Oh and dont forget the sway bar. I think thats about it. Pretty easy to do.
Old Nov 19, 2003 | 02:22 PM
SS GIRL's Avatar
how much harder is it to take it out the bottom than the top?? i was going to take mine out the top becuase i dont think mine is high enough in the air!! i have a lift i can borrow but im already doin it at my house... and the lift is about 15 min away also... thanks
Old Nov 19, 2003 | 03:43 PM
tony124's Avatar
Thanks
Old Nov 19, 2003 | 04:25 PM
Smoke_Ford's Avatar
1 hour out the bottom, 6 out the top. I did mine out the top in my garage. Guys at work have the thing sitting in parts 1 hour after they start working on the car... Much easier out the top, but you need a lift.
