The New Seafoam??
Best way, take the MAF off and spray both sides. Let it air dry and you're done.
Lift the lid as well and spray the hell out of the IAT sensor that mounted in the lid. That thing gets very dirty too.
Thats why I said the best way is to take the MAF off the engine to clean it. Spray it and let it dry. I also mentioned lifting the lid and spraying the IAT, which you shouldn't do with the engine running.
BUT....either way, you definitely cleaned your MAF. If its running better maybe you solved the problem.
Are you saying you sprayed a can of MAF cleaner in the engine through the MAF....or a can of MCCC?
I hope it wasn't a can of MCCC.
MCCC is so simple to use. Pull off the PCV hose and hook up a piece of 3/8" heater hose, spray it in while the engine is already hot and idling. Shut the engine off right BEFORE the can runs out. Put the PCV hose back on and wait 1 hour.
Thats it.
http://www.turbomopar.com/neon/mccc/
Does anybody have the part number for the MCCC in case they try and hide it from me at the shop?
