Sponsored by: CARiD
Failed CO Emissions.
Old Aug 17, 2009 | 06:53 AM
Torque666's Avatar
Originally Posted by LS14EVR
Back when we had to pass emissions tests in MI, I used to run about 3-5 cans of gas line antifreeze in the gas. I had a small pick up that was way over the limit. Got 4 cans of antifreeze, ran the crap out of her, brought it back 15 min later and the got a 0.0 ppm reading. The tech's jaw was on the floor and couldn't figure out what I did.
Yeah...? Whats Gas Line Antifreeze?
(From Australia & don't know the term?)
Old Aug 17, 2009 | 07:45 AM
LS14EVR's Avatar
Try this.
http://www.amazon.com/Eagle-28201-An.../dp/B0016GXNC4
Old Aug 17, 2009 | 08:16 AM
fleetmgr's Avatar
It's stuff you put in your gas that keeps any entrained water in it from freezing.
Old Aug 17, 2009 | 11:49 AM
jimmyblue's Avatar
Moderator
It's mostly methanol and an old school trick to lean
out the mixture. That workes well for open loop
(like carb'd vehicles) but will get learned out in
time with a closed loop setup.
There may be burn-profile effects as well but what
I've seen, is pretty much just about mixture.
Old Aug 17, 2009 | 02:07 PM
Hawk777th's Avatar
Im gonna go try some I have half a tank in my ss how much would you add? Also how long will it take for computer to change mixture with heet in there.
As you can see its NOX im failing so I put in the cooler tstat.
Also I was told E-85 does anyone have any thoughts on that?
Old Aug 17, 2009 | 05:06 PM
LS14EVR's Avatar
I always wondered about the closed loop. Never had to try it on one. So it may learn it and adjust too quickly. But still worth a shot.
When I used to do this, with a half tank, I'd add about 3 cans maybe. Then go run the crap out of it for 10 min after it's warmed up of course, then hit the test station while still hot. Who knows, you might just luck out.
I wouldn't use E85. That's ethanol. The antifreeze is either Isopropil or Methanol.
Old Aug 17, 2009 | 05:27 PM
vaticano's Avatar
The reason you can't get 93 here is because you don't need it. The higher altitude requires less octane. It appears to me that your tune is no good. Looks like you are getting to much fuel on both acceleration and deceleration. Seems like you have aftermarket injectors that were not tuned properly. Sending PM.
Old Nov 20, 2009 | 10:09 AM
Camaro_Zach's Avatar
Originally Posted by dragonrage
Awesome tip; I'll keep it in mind if I'm ever in that situation.
And Ill report you to the EPA for cheating the system.
Old Nov 20, 2009 | 10:35 AM
allan808's Avatar
watch out he'll tattle tale on ya,its a sad day when fellow rodders are ratting out other rodders!!
Old Nov 20, 2009 | 12:33 PM
I was mocking him because he said he was going to report a speed shop for headlight sales?
https://ls1tech.com/forums/12523688-post55.html
Old Nov 22, 2009 | 01:51 AM
allan808's Avatar
my bad!!
Old Nov 22, 2009 | 09:28 PM
  #32
DarkJuggalo's Avatar
im not too sure if it works in our cars, but worked in my 86 iroc, LTs, no cats and a monster cam. ofcourse thats a carbed car, but we used dry gas, and it passed with flying colors after failing 3x and being red flagged.
