New PCV experiment......
Would just have to do a test to see if it creates enough suction. If it does, a PCV valve could also be put in line if desired.
Or...a venturi. Its can me mounted low, maybe right in front of the air dam to catch air while moving. That can be attached to a line and also draw air from the crankcase that way.
BUT...a simple electric pusher air pump to push fresh air into the crankcase continually through the valley cover port and let it escape through the valve cover port vents...I think is the best.
I was curious, did you ever do the needle valve thing?
If you want to do the oil analysis thing, go here: http://polarislabs1.com/
The way it works is you send them I think $20. You'll get a sample bottle and a mailer. You'll need a little hand pump (Harbor Freight has a couple). As the method of pulling the sample can have a significant impact on the results, ya gotta be careful and do it right. If you want, PM me and I'll give you directions.
I'll look into that oil analysis, I'll try to do it this coming week. I'm kind of curious too.
I looked at their site...there's a ton of things they can test for. What should I have tested?
When you get the results, you'll get a print out showing all the parameters I mentioned plus the chemist's recommendation as to what you should do. Over time, these reports will give you a very good idea of what is going on inside the engine. What the chemist says about the condition of the oil is 100% definitive, assuming you've done your part when taking the sample. How you draw the sample is as important as the sample itself, as doing it wrong will skew the results...sometimes severely.
PM the directions how to get the oil out properly. Thanks.
Curious to what classes and what tracks they run at?
At the very least drag only motors have a scavange evac system in the header colletors to pull vac, and anyone thats serious has a belt driven vac pump.....especially the Alky motors due to the amount of moisture the alchol introduces to the crankcase. Next time your at a sanctioned )NHRA/IHRA) race walk around the pits and look at the dragster motors and how they evac. You will see that any w/a vac pump run a relief valve on the opposite valve cover because if you pul any more than 14-15" of vac you start to pull oil off the wrist pins & rod journals.
The reason I ask about all these friends drag racing high HP v8's you claim run no vac source for evac is I have run a pro team for 7 years and we run most every sanctioned track in the Eastern US and have yet to see a high HP dragster or door car w/out evac so I'm curious to what class they race and where.
The oil analysis will show the acid build up....and no, it takes a year or two before you would see any substantial damage to your internal engine parts.....but an easy way is after 6 mnths or so of runninng like you describe pull a valve cover and look and the corrosion from the vapors on your rocker arms. This is the first place it is visable.
More of my background? My team holds several local, divisonal, National, & World championships in Super Pro, Super Comp, Quickrod, Top Dragster, and non-electronics.....I am also a graduate of the Reher Morrision Racing engine building school and have been an engine builder for over 35 years. Take a little time & read David Reher's tech tips......a world of information: http://www.rehermorrison.com/blog/?cat=3
Bottom line is, w/out a proper evac system you WILL sustain long term engine damage. It may take a few years to notice, but I build motors 6 days a week when not racing and se the results first hand.
Now on big cam/stroker builds a can inline on the dirty side, and a can inline from the fresh air source may be needed (the bigger the bore & longer the stroke, the more crankcase pressure is built up) If it is forced induction, then you have a whole new process to deal with......and that is the PCV system works proerly when at idle & non-boost, but when you start making boost you have switched from the intake manifold being negative atmosphere to a pressurized component and the PCV system is rendered useless and pressure escapes wherever it can. The solution then is to have oneway check valves inline so the vacuum need for proper evacuation comes from in front of the compressor (head unit) through a line run to the air filter.
This is getting a bit long and I hope all can follow this, but if not ask me specific questions for clarification so this helps all. I'll go over every type of solution and the pros & cons of each....and remeber, this problem is NOT just in the GM LS based engines, but is an issue with ALL modern closed systems. We just tear into our cars where as the Mercedes or Lincoln owner never even realizes there is an issue.
I also wanted to address the water in the oil. You will NOT fill your crankcase up in short order with just breathers. What happens is each time your engine reaches operating temp the unburnt fuel, water vapor, combustion by-products will gass or "flash-off" as vapor. But only the excess crankcase pressure being relieved through the breather will carry any of that out....and without a proper evac system, a good amount remains in the crankcase and recondenses back to droplets that coat the internal engine parts as your motor cools down and it contaminates the oil. Every time you heat cycle you are adding more contamination and it is not very visable to just "look" at your oil....you need a proffesional analysis to see just what is accumulating in your oil and how it is breaking down its ability to protect...but the corrosion from the sulferic acid is also very damaging over time (I'll try to post up some pics of parts showing just this in the near future). Just pull the dipstick on a diesel 20 miles after an oil change...it already "looks" black & dirty, but is still new and providing the proper protection. Sight is deceiving. Oil might look pretty clean but an analysis report will show destructive levels of contaminants.
I'll add more after some more questions come in.
It will take some time and multiple samples to see the affects.
My 99 has burned some oil from day 1 and it has increased every time I increased the stall. Oil gets black fast. Different heads/cams didn't really change it much, just higher stall. The entire intake manifold has an even film of oil inside and the intake ports of the heads are stained with it, same amount each one. Now with my 4200 stall I burn a qt of Mobil1 every ~300 mi.
I tried the "orificed" PCV which did nothing. I had an AMW catch can on the dirty side years ago which caught a small fraction of the total. Did the LS6 valley conversion, no change. This has been the single most frustrating PITA with this car. My 99 has burned some oil from day 1 and it has increased every time I increased the stall. Oil gets black fast. Different heads/cams didn't really change it much, just higher stall. The entire intake manifold has an even film of oil inside and the intake ports of the heads are stained with it, same amount each one. Now with my 4200 stall I burn a qt of Mobil1 every ~300 mi.
I tried the "orificed" PCV which did nothing. I had an AMW catch can on the dirty side years ago which caught a small fraction of the total. Did the LS6 valley conversion, no change. This has been the single most frustrating PITA with this car.My 99 has burned some oil from day 1 and it has increased every time I increased the stall. Oil gets black fast. Different heads/cams didn't really change it much, just higher stall. The entire intake manifold has an even film of oil inside and the intake ports of the heads are stained with it, same amount each one. Now with my 4200 stall I burn a qt of Mobil1 every ~300 mi.
