Sponsored by: CARiD
Dealer doesn't know!
Old Oct 5, 2009 | 09:58 PM
plan Z's Avatar
i figured out what my problem was! i replaced the ignition switch above the steering column. apparently the starter just wasnt getting enough juice on the smaller wire coming from the ignition switch. the bendex would click a lot of the time against the flexplate and when it did engage fully, sometimes it would grind (i guess due to not staying extended all the way while turning) and then sometimes break the nose off. may not be the same problem you're having but it was a fix in my case.
Old Oct 8, 2009 | 11:29 AM
adam1803's Avatar
Originally Posted by Marc 85Z28
A hydrolock condition is the most common reason for this type of failure. Either a leaking injector filling the cylinder with gasoline, or a leaking injector O-ring filling the cylinder with water.
BINGO! I went through this exact same thing with the 408 i had in my old truck, after about 5 starters it ended up busting a rod on startup.
