Installed A/C...can NOT get compressor to kick on...
With everything installed on the Trans Am, The ONLY way the compressor will kick on is with the scanner tool in hptuners and its manually clicked "on'. Everything else works inside the car, the controls all work as they should.
I have even swapped sensors on the bottom line and it still won't kick the compressor on. It has been charged up, so the low pressure sensor wouldn't be an issue...
Does anyone have any advice? I am out of ideas on how to fix this thing, and in the meantime I am roasting in this 90degree heat!! heh
If you have a set of gauges, checking the pressure is not a bad idea.
Ryan
How could the compressor be commanded ON via hptuners, but not from inside the car with the climate controls?
I would not expect this, as it is not necessary, but it is something to take a look at.
