Sponsored by: CARiD
Timing question
Old Aug 10, 2009 | 10:57 AM
xbcrguy182x's Avatar
Default Timing question
Hey everyone. I have a Scangauge device which is pretty cool. Tells you info about your car and such. Anyway, I was wondering, according to it, my timing is never advanced, always retard. Usually between -17 and -25 when driving around. Is this normal? I always use 93 Octane fuel. However, I am getting pretty bad gas mileage.
Old Aug 11, 2009 | 08:59 AM
NeXuS's Avatar
Same question for me.. i noticed with my scanner it says like -5 to -10 on idle.. going WOT it will be like -30+ i think that it is just confused and its really + .. but maybe someone can shed some light on this.
Old Aug 12, 2009 | 12:06 AM
technicality's Avatar
i have a scan gauge also and it usually runs between 10 and 25 advance. never retarded... might be ur knock sensor pulling time. do u have headers? if u do you need to have the LT4 knock module installed because the stock LT1 knock module is very sensitive to noises that the headers create. this is only one possibility...
Old Aug 12, 2009 | 01:10 PM
Interesting. No headers installed.
Old Aug 12, 2009 | 04:47 PM
Ok. I got it. Someone explaind it to me. The -17 means before TDC, not the degrees.
