Sponsored by: CARiD
Spark Plug replacement
Old Aug 21, 2009 | 10:26 AM
steve2002ss's Avatar
Default Spark Plug replacement
what I got here is camero 2002 ss convertable no problems 86,000 mile time to change the Spark plugs you think. do I go OEM AC DELCO AC41-985 OE 12571164 gap 0.05 or do I go best choice BOSH 8S4505 Premiun class platinemin fusion no gap or then their is performance ACCEL A35p526s . Got good long life from OEMS will I have the same from the BOSH ??
what you all expereance
Old Aug 21, 2009 | 10:37 AM
cputech's Avatar
Your Camaro may like NGK-TR55's at .055
Old Aug 21, 2009 | 10:48 AM
TT632's Avatar
Any name brand plug with history will suit you fine. With the advent of internet experts, many would lead you to believe that one specific brand spark plug and part # is the way to go. It's ridiculas that people on internet sites actually list their spark plugs when they show their engines modifications.
Personally, I use Autolite cut back strap race plugs, even in street driven performance cars. For one, they are American made and two, I have never had one go bad in 30 years of racing. Like I said above, any name brand plug with history will give you good performance and life.
Old Aug 21, 2009 | 01:14 PM
91RS383's Avatar
Don't bother waisting your cash on gimmicky plugs. Platinum fusion or Platinum +4 or diamond fire etc. are all ways marketing geniuses have devised to grab more market share.
I personally run NGKs in my street rides, and the race cars have autolites. I do think they are different animals as the race cars run much more juice through the plug wires.
Old Aug 21, 2009 | 01:46 PM
LS14EVR's Avatar
Me personally... I'll run just about anything BUT a Champion. Just nothing but bad luck with them.
Agree with most above though.
Old Aug 21, 2009 | 02:12 PM
LS6427's Avatar
JUst use NGK TR55 gapped .050
All those special, super duper plugs...are bullshit.
Old Aug 21, 2009 | 03:34 PM
fleetmgr's Avatar
BUT, BUT, BUT...people LIKE snake oil!!!
Old Aug 21, 2009 | 03:51 PM
LS6427's Avatar
I'll tell ya one wierd as hell thing with my car/PCM/engine.
My engine will not run with Bosch 02 sensors, it just sits and sputters and coughs and if I try to put it in gear and go it stalls. The same exact thing happens if I install Bosch spark plugs.
Thats some wierd **** right there. Its like my PCM doesn't want Bosch on the car.
If I pull the Bosch 02 sensors out and install GM or Densos...perfect.
Same with the plugs....pull them and put in AC Delco or NGK...perfect.
I've also tried those polugs with the two electrodes for better sprak coverage....had zero effect on my engine and so expensive, like $6.00 per plug.
Maybe my engine/PCM just likes the most basic of things Regular oil, paper air filters, regular spark plugs, cheap serpentine belts that last 6+ years, still have my factory 11+ year old spark plug wires, etc....
Old Aug 21, 2009 | 04:03 PM
fleetmgr's Avatar
Years ago, like in the mid 70's, the biggie was AC plugs. We quit using them in the shop once we got a new scope in and could see that they were shorting out as they came out of the box. I think they had some other issues, but don't remember for sure.
Old Aug 22, 2009 | 02:47 AM
kdoublep's Avatar
I changed my original plugs at 75K. I also changed the wires. I went with original plugs because my car loves them and they last forever. I bought this car brand new in 1998 and I now have 93K on it. It is a dd with minor mods and modest power. See sig for details and Dyno info. Nothing special. The point I am making is that it all depends on what you use your car for.
This site is loaded with many valid opinions based on experience and you can easily turn into a wall banger. All you have to do is a search and you can read for the next two days about spark plugs and which is the best and what to set the gap at.
You also may want to consider how often you would like to change the plugs. The originals are expensive but will save you the heartache of the most difficult plug change ever experienced by mankind. These cars are a buster! The first seven will take about 10 mins. and the eighth (i forget what the official number of the plug) will take an hour and a pound of flesh.
Make sure you apply a little anti-seize on the new plugs to make the next change a little easier.
Do a search so you know what to expect for this task. Their is some great advice and tools that many have used to make the job easier.
Welcome to the party!
Old Aug 22, 2009 | 12:48 PM
LS6427's Avatar
Expensive? You mean AC Delco plugs. They're about the cheapest plugs on the market. I use NGK, they're like $16.00 for all 8.
Old Aug 22, 2009 | 02:24 PM
kdoublep's Avatar
The irridiums are expensive and last about 75K.
Old Aug 22, 2009 | 02:37 PM
ls1rules¡¡¡'s Avatar
X 2, i made a mistake when i put that sh** on my Z 28, smoke, lose power, poor fuel economy..never again
Old Aug 22, 2009 | 02:44 PM
Midnight00SS's Avatar
can i also run the ngk tr 55's at 0.50?? i have a 2000 SS with msd wires on there but original plugs at 29k
Old Aug 22, 2009 | 02:50 PM
LS6427's Avatar
Any LSx engine, whether its stock or 600 hp.....as long as its not a nitrous or a forced induction set-up.......NGK TR55 gapped @ .050 will be perfect for them all.
I've done .040, .045, .050, .055 and .060. On my stock engine and on my 427ci....zero difference in them all.
Old Aug 22, 2009 | 06:18 PM
01WS6er's Avatar
a little of advise the ACDELCO plugs for the lsx engines are made by NGK. they have NGK stamped on them as well as ACDELCO
Old Aug 24, 2009 | 09:49 PM
Johnnystock's Avatar
TR55 cheap and works good.. anyway, no plug last longer than 5K miles on my car... TR6 with nitrous for me.
Old Aug 24, 2009 | 11:41 PM
ok cool, thanks for the help
Old Aug 25, 2009 | 02:15 AM
LS1nut377's Avatar
ok---- TR55 NGK plugs those are the best, .055 gap pick up some spark plug wires while your at it.
Old Aug 25, 2009 | 03:02 AM
flippincamaro's Avatar
I run ngk tr55 in all mine that is na and tr6 on all mine that are boost or nitrous, but if its not missing or running crappy I wouldnt change the plugs out yet.
