would WOT brake my A/C
If it's not doing that, I can see your problem happening. Incidentally, you're giving up 20 - 25 HP by running with it engaged.
Some have a stupid-low re-engage RPM (like 0) which would
make the A/C quit until next key-on cycle. But dead like dead,
is something else.
You should look for immature codes, and try using a scan tool
to force A/C compressor clutch engagement, check pressures
etc. so you know for sure you're not throwing hardware at a soft
problem. All best done on your driveway, where nobody profits
by selling you stuff you don't need just because it makes the
diagnostics "done".
Some cars, ie the 98's had a problem with the first release calibration did not shut off the AC compressor at WOT, but the newer updated calibrations do. Might be something to check out. (if you want me to look at your tune, let me know)
Ryan
If I'm cruising on the highway with my A/C "on" and I just get into the thorttle pretty hard just to pass someone or just to haul ***, but NOT going WOT, it will shut off too. Then immediately come back on when I relieve that pedal input.
Its simply a compressor safety mechanism in the PCM. So yeah...going WOT will probably kill a compressor if that mechanism is not working.
Stop racing with the A/C "on".
to look at these A/C control settings and verify that (a)
it does get told to cut out at some reasonably low RPM
and (b) the re-engage RPM is also greater than idle RPM
+ hysteresis.
There's plenty of variation in stock tunes, let alone what
somebody might go make up. You really ought to do the
scanning though, to narrow it down to fault or intention.
