Only Defrost Vent Blowing...
Stopped at a job site to do some computer work. When I started to leave, I noticed that only my defrost vent was blowing no matter what setting I turned it to.
I've never messed with the HVAC system, so I'm not even sure where to begin. Did a quick search here on the forum and didn't come up with much.
Is there a particular fitting that is known to go bad over time? Any tips on where to start looking?
If this is disconnected it will cause this same thing to happen. Does the ac switch freely spin?
I know the vacuum line you are referring to. I'll check it out. Thanks guys.
Good Luck!
