Sponsored by: CARiD
Stupid Beginner question...
Old Sep 24, 2009 | 03:08 AM
Jasey's Avatar
Default Stupid Beginner question...
Where is the flasher located at?
Old Sep 24, 2009 | 03:13 AM
lemons12's Avatar
if same on the TAs (which IIRC it is) it is on the right of the steering column.. push in for on and pull out for off..
Old Sep 24, 2009 | 09:17 AM
BlurSS's Avatar
That was easy.
Old Sep 24, 2009 | 09:23 AM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
The switch for the flashers, or the flasher relay?
Old Sep 24, 2009 | 09:20 PM
Jasey's Avatar
Not the switch, the RELAY. thank you for pointing that out.
Old Sep 25, 2009 | 02:38 PM
cambirdracing's Avatar
Between the fuse panel and the steering column, under the dash. Does it work on one side and not the other, or not at all?
Old Oct 8, 2009 | 08:41 AM
Jasey's Avatar
Hazards are fine, Just when I hit the turn signal left or right, neither side works. I checked fuses & they're fine. Flahser I presume?
Old Oct 10, 2009 | 09:38 PM
95TAJade's Avatar
Could be your dual filament bulbs, or some corrosion on the bulb connectors.
