Post Battery Disconnect Behavior
Old 10-08-2009, 07:44 PM
Disciple's Avatar
Default Post Battery Disconnect Behavior
My vehicle is a 2000 Trans Am, stock automatic drivetrain w/GU5.
After having had my battery disconnected throughout last Saturday while installing a relay harness for new fog lights and the lights themselves, I suspect something has subtly altered in the vehicle behavior.
When I first reconnected the battery, the vehicle did not start up smoothly. It turned over for a few seconds, made annoying coughing noises and died. The second try it started right up and then hunted around until it settled in at about 500 RPMs after a few minutes [the reading was based on the dashboard tachometer].
Since then , acceleration seems "mushy" is the best way I can describe it. At times it almost seems like acceleration is lagging the engine. Is there any training or relearning that needs to take place? Anything to poke at?
Old 10-25-2009, 07:31 AM
dh007's Avatar
the ECM lost its history and is re learning the car it will finish when all sensors come out of not ready about 50 miles
Old 10-25-2009, 02:05 PM
shaun's Avatar
the idle has to relearn it self just give it a few miles.
