Sponsored by: CARiD
Help! starter removal
Old Oct 18, 2009 | 03:45 PM
bigbirddriver94's Avatar
Default Help! starter removal
so my starter went out and i got a lower miles gm replacement. i got the two wires connecting to the solenoid off as well as the two bolts holding the starter in place. it looked like it would be a tight fit removing the starter past the y pipe but looked like it would fit. however i can not get it out. has anyone found a way to remove and replace the starter without unbolting the y pipe?
btw car is a 94 LT1 A4
Old Oct 19, 2009 | 09:38 AM
so nobody has had to do this before? im just looking for options other than unbolting the y pipe. will dropping the oil pan give me the clearance?
Old Oct 19, 2009 | 11:21 AM
99RTA's Avatar
Maybe pull the solenoid off.
Old Oct 19, 2009 | 01:18 PM
94'BLKBRD's Avatar
Unbolt the y-pipe. Don't attempt to remove the solenoid while the starter in on the car.
Old Oct 30, 2009 | 05:00 PM
Bump. i have a serious problem here. hasnt anybody done this before?????
Old Oct 30, 2009 | 05:23 PM
94'BLKBRD's Avatar
Unbolt the y-pipe, not that big of a deal.
Old Nov 2, 2009 | 09:16 AM
i tried all afternoon with and went throug a can of pb and i only managed to get one manifold bolt off and snapping another. and i cant get a griner in to cut them. im thinking i mite just say the hell with it and get headers
Old Nov 12, 2009 | 10:30 PM
well guys i solved my own problem here. after struggling with those seized y pipe bolts and then trying to remove it from the front with no success. i simply took the four bolts off of my flywheel cover and dropped it right. prolly took five minutes.
i cant believe i didnt think of it before, but hey who doesnt drop the ball every now and then
Old Nov 12, 2009 | 10:32 PM
too bad the starter i ordered was the wrong one though
