I need HELP. Purge Valve Solenoid?
I went to go take my car for a spin and my check "engine soon light" was on so I want to auto zone.
Its the codes P0443 & P0449
BB1 Purge or vent solenoids defective
BB2 Check connector and wiring
BB3 Fuel saturated vapor canister
BB4 Failed EVAP vent solenoid
BB1 Blocked purge hoses
BB2 Faulty canister vent control value
BB3 Plugged EVAP canister
BB4 Faulty EVAP canister purge volume control solenoid valve
My question is. Is this a big deal that I should be fixing ASAP? And where in the hell is this locationed at? It looks like an easy fix I just dont know where the part is located at pictures would be nice.
purge valve sol. is the black cylinder over the #1 coil near the intake tb. youll see a hose running to it from the driver side of the intake...that takes the pressure from the gas tank out into the motor so pressure doesnt bild up in the tank
