Sponsored by: CARiD
Low Coolant Light on
Old Oct 26, 2009 | 02:07 AM
Chase22's Avatar
Default Low Coolant Light on
This light has been on for about 3 weeks and I put radiator fluid in 2 weeks ago. I checked it again this morning and it was fine. Is there any way to "reset" this.
Old Oct 26, 2009 | 02:12 AM
Sabaktes's Avatar
The low coolant light being on is a common issue.
You'll have to replace the sensor.
Old Oct 26, 2009 | 08:54 AM
pjb's Avatar
pjb
I had a problem with my PS cooler leaking, contaiminating the coolant low sensor and giving a false low light.
Old Oct 28, 2009 | 08:36 AM
Danny2tek's Avatar
bad sensor
Old Oct 28, 2009 | 08:47 AM
buddha845's Avatar
Originally Posted by Danny2tek
bad sensor
^^ ive got the same problem, anyone got a part #?
pjb's Avatar
pjb
I've cleaned mine, after fixing the PS fluid leak, and it worked.
Old Oct 28, 2009 | 08:50 AM
buddha845's Avatar
ive heard of this as an easy fix but ive never tried it for some reason lol, is it as easy as it sounds to clean or?
Old Oct 28, 2009 | 08:54 AM
pjb's Avatar
pjb
sensor pops right out of radiator. scrub it with an old toothbrush and reinstall.
Old Oct 28, 2009 | 08:57 AM
buddha845's Avatar
awesome, ill give it a try after class. good info
Old Oct 28, 2009 | 05:17 PM
Shake's Avatar
If that doesn't work, then I know they sell them at Autozone. But last time I checked, they wanted about $40 for it.
That's why I just unplugged the wiring harness to mine....no more light on the dash.
Old Oct 28, 2009 | 07:33 PM
00Silv4.8's Avatar
clean it or buy a new one. I havent had a chance to clean mine yet
Old Oct 28, 2009 | 10:40 PM
Circa307's Avatar
mine does that same thing. waiting till i flush my rad. this spring
Old Oct 28, 2009 | 11:33 PM
wssix99's Avatar
Save the manuals!
This is bad. The sensor is there to warn of a condition your coolant temp sensor can't. No coolant = bad temp reading. If you drop low on coolant, your block could overheat and start to deform before you even know it.
Is that worth $40??? I think so - but you can get the part less from gmpartsdirect.
Old Oct 29, 2009 | 03:08 PM
98TAjwh's Avatar
clean your sensor, if that doesn't work buy a new one. i got mine on rockauto.com for about 30.00 if i remember right. i know it was way less than auto zone.
Old Dec 1, 2009 | 10:32 AM
Danny2tek's Avatar
bad sensor
Damn should've kept my mouth shut, mine crapped out
Its been like five years since I replaced it, I forgot theres a trick to the removal right? I think it was turn/twist and remove?
Old Dec 1, 2009 | 11:17 AM
pjb's Avatar
pjb
check for PS fluid contamination from the PS cooler, if you have one. The PS fluid will cause it to give a false light.
Old Dec 1, 2009 | 11:54 AM
fleetmgr's Avatar
Cut the wire clip that holds it in with wire cutters, remove the old sensor by pulling it out. Slide new sensor in, it comes with a new clip.
Old Dec 1, 2009 | 11:57 AM
pjb's Avatar
pjb
why cut the wire clip since it pops right off?
Old Dec 1, 2009 | 11:59 AM
Aetos's Avatar
just keep the sensor taped off and check your coolant regularly.... that's what I do.... lol
Old Dec 1, 2009 | 12:53 PM
eseibel67's Avatar
Standard part# FLS24.
