Sponsored by: CARiD
Code help
Old Oct 29, 2009 | 07:35 PM
noolah's Avatar
Default Code help
Hi guys i just had headers and a y pipe installed and i am getting 0140, 0160, and 400. I am pretty sure the 140 and 160 are the 2 o2 sensors that are no longer on the pipe, and the 400 is the egr with also no longer is hooked up. Is this fixed by a tune? Also i am getting 1441 which is the incorrect purge flow. any ideas how to fix the purge flow>? Thanks.
Old Oct 29, 2009 | 10:47 PM
98pontiac's Avatar
1441 is an evap code. There is a purge solonoid on the drivers side of the intake, see if that is plugged in, and lines going to it or tight and hooked up. the other codes can be tuned out.
