Sponsored by: CARiD
Check Engine Light
Old Nov 11, 2009 | 05:42 PM
JohnnyBz28's Avatar
Default Check Engine Light
I just picked my Camaro up from the body shop and now the check engine light is on. It runs perfect and I didn't notice anything wrong. They only removed the plastic piece around the filler neck for the gas tank and dropped the bumper on the drivers side.
Any ideas as to what it could be? (I don't have a code scanner otherwise I'd know LOL)
Old Nov 11, 2009 | 06:51 PM
LS6427's Avatar
Go get a free scan and tell us the code. Maybe something with the evap and the gas filler neck??????
Could be a hundred different things.
Old Nov 11, 2009 | 07:43 PM
ssdeuce74's Avatar
if it's anything to do with there work its probably an evap code make sure your gas caps tight check vent hoses from filler neck
Old Nov 11, 2009 | 10:31 PM
JohnnyBz28's Avatar
got a friend who met me just a few minutes ago with a scanner. both codes are o2 sensor codes: P0161 P0155
Old Nov 12, 2009 | 05:00 AM
eseibel67's Avatar
Check your ENG SEN fuse first.
Old Nov 12, 2009 | 08:12 AM
JohnnyBz28's Avatar
okay thanks
