TONS of noises...help please
1. It sounds like a ball joint up front that sometimes squeaks going down the road and when I stop and get out of the car it will make a big squeak...but it's super inconsistent...it hasn't done it in a couple weeks but it always comes back...I greased it so any ideas
2. It's a high frequency buzz that sounds like it's coming from the rear hatch glass and sounds like a loose nut or bolt...happens cruising in 6th at about 70-75 then goes away...but only when I'm on the gas
3. Seems like the door lock sliders...you know the little red ones...rattle like crazy...ahhhhhh
4. A squeak that sounds like it's a rear shock or spring...I pulled down on the car when I was under it and I just couldn't pinpoint it by myself...I sprayed every bushing and shock end and spring with a ton of wd40 and it went away for like a day haha...(sidenote) passenger rear sits about an inch lower than driver...bugs the **** outa me...think it's related?
5. Car has aftermarket lca's and torque arm and panhard rod....the lca's and panhard rod have heim joints on the ends...when I go down my driveway (gravel) or a bumpy road sounds like the back of the car is falling apart...would stock parts alleviate this or just aftermarket parts with bushings?? I got the car with all these parts on it so don't know if when they were put on is when the problems started.
6. And at low speeds it sometimes feels like I've got a clunk in the steering
7. Passenger door speaker seems to buzz when a little bass hits it...that normal or it blown?
Well I guess that about sums it up haha...I love the car but I'm super **** about noises and rattles and this car is full of em...Any help is gonna be great
As for #2, I had a similar problem, I tracked it down to the spring that opens the rear hatch. I took it out, and now I use the key to open it lol.
good luck!
In the mean time:
#1 sounds like a dry sway bar bushing. Remove it and slather the inside with lithium grease. Might as well do both while the bar is dropped.
Anybody have any ideas about the panhard rod making so much noise on bumpy surfaces?? Is that kinda normal??
Materials needed:
2 bottles of quality synthetic diff fluid (make sure it has lsd additive or buy some to add to the oil)
Diff gasket (or you can use RTV sealant)
Grease to coat both sides of the gasket prior to install. (makes the next oil change easier)
Check it out: http://syclone.motocrew.com/CG5/swaylube.htm
I have some heim joints on my Jeep suspension. I'm going to try some of this http://www.whitelightningco.com/products/index.htm next time. It's sold at bike stores and is used on chains and such. It's a dry wax lube that protects and keeps dirt out of the moving bits.
1. buy factory used speakers on e-bay
2. get a new head unit and rewire the car
3. Do a little electrical work on your new speakers.
Buy some 2 or 3 way speakers for the doors
the wires for the main speaker and the tweeter will go to a single plug
you will need to disconnect the wires from the plug and solder the plug from your blown speaker to the new speaker. The old plug will have separate leads for the primary speaker and the tweeter.
If you coppy the setup of the old monsoon speaker onto your new 2-way speaker you can use a standard 4ohm speaker.
The speakers behind the front seats are for bass only so just get one way speakers for those.
If you replace all those the next speakers to blow will be the tiny 2ohm tweeters in the rear. You can directly replace those with 4ohm after market units.
