Sponsored by: CARiD
Replacing Blinker Light
Old Dec 1, 2009 | 05:49 PM
Mong00z's Avatar
Default Replacing Blinker Light
Well, the Camaro just hit 100k miles and it seems everything electrical is giving me trouble all the sudden, particularly the front right blinker(bulb). Has anyone here had to replace one yet? Do you have to pull anything off? Its a freggin pain to get to and I'm having trouble getting ahold of it to get it unscrewed. . .
Old Dec 1, 2009 | 06:37 PM
texas99Z28's Avatar
Use a 10MM socket...pull down plastic trim ****... and reach up in there! closer towards center of bumper than you would think! Turn 1/4 turn counterclockwise... and pull out old bulb, and plug in new one. Have to do it one handed! Have fun! Just changed mine out. Hardest part is getting new bulb plugged in.
Old Dec 1, 2009 | 06:38 PM
98LS1Kid's Avatar
I did not have to take anything off to get to it. But then again my hands are not that big. For the left side I went under the car and removed the plastic and reached up and unscrewed it.
Old Dec 1, 2009 | 09:31 PM
wssix99's Avatar
Save the manuals!
Yea - there is a "trap door" on the bottom of the bumper that allows you to get to them.
Old Dec 1, 2009 | 09:40 PM
Anthony Williams's Avatar
I just pull the headlight, Remove the 2 10mm brace bolts, un hook the headlight electrical connectors and slide the headlight towards the middle of the car (to the left for the right HL, and to the right for the left HL) out comes the HL. Put some dielectric grease in the bulb socket, clean the bulb with alcohol or brake parts cleaner and don't handle the bulb bare handed the oil from your fingers will shorten the bulbs life.
↓ Actually you don't have to re-aim the lights since you don't move the adjustors, my car is lowerd so it is easyer for me to do it from the top.
Old Dec 1, 2009 | 11:08 PM
crimson_bird's Avatar
^ the headlight way is much more time cunsuming, and worst of all, you have to realign them when your done. going in from the bottom, through the "trap door" is much easier.
Old Dec 1, 2009 | 11:23 PM
bill12690's Avatar
I've been having a different problem with my front pass. side blinker.. my bulb went out, I replaced it, and about a week later it went out again. replaced it again and it did the same thing. went through 2 bulbs in 2 weeks. Took a look at the connector and you can tell where it's gotten pretty hot because the plastic is slightly melted. I could just replace the connector but.... any opinions on what caused it?
Old Dec 2, 2009 | 07:46 AM
wssix99's Avatar
Save the manuals!
Look to make sure your lens isn't cracked. If water gets in, it will cause your bulb to blow every time. Look for pools of water in the bottom of the lens and/or press on the front to see if you get any separation of cracks.
Old Dec 4, 2009 | 11:29 PM
bill12690's Avatar
Already checked that, no cracks or moisture in the housing. The one thing that concerns me is how hot the bulb has gotten, hot enough to deform some of the plug.
On a side note, can the housing be changed without removing the bumper? I tried through the trap door but couldn't quite get it out, it kept snagging on something..
