Sponsored by: CARiD
Failing O2 Sensor?
Old Aug 25, 2010 | 08:42 PM
Formulals187's Avatar
Whats the better oxygen sensor between the Bosch 13444 and the Denso 2344087?
Old Aug 26, 2010 | 04:52 PM
Anyone?
Old Aug 27, 2010 | 07:26 AM
Which one is better for performance apps?
Old Aug 27, 2010 | 07:58 AM
eseibel67's Avatar
Yes, a ported TB can cause a high idle if it wasn't done right and the IAC is bottomed out.
You need a scanner with data stream to see what's going on.
Old Aug 27, 2010 | 11:13 AM
The car threw a P0131 P0137 and P0171 codes. Is there anyway to differentiate if the codes are for a front or rear oxygen sensor?
Old Aug 27, 2010 | 11:44 AM
eseibel67's Avatar
Those are all lean codes. Check for vacuum leaks.
Old Aug 27, 2010 | 04:34 PM
senicalj4579's Avatar
Are you asking if those codes are saying which sensor locations they are?
Old Aug 27, 2010 | 04:38 PM
Yeah, I was trying to figure out if one of them was saying the front O2 sensor is going out.
Old Aug 27, 2010 | 05:14 PM
bank 1 is driver side
bank 2 is pass side
sensors 1 are front
sensors 2 are rear
Do a google search for the codes. What I wrote above will help identify which sensors the codes are talking about. That should help
Old Aug 27, 2010 | 06:21 PM
So for the front O2 sensors, whats the better oxygen sensor between the Bosch 13444 and the Denso 2344087?
Old Aug 27, 2010 | 06:43 PM
Theres no real answer for that. All your gonna hear is opinions. I have the bosch vette o2s with long extentions for my lts.
Old Aug 27, 2010 | 11:37 PM
  #32
Well I went with the Bosch 13444. Hopefully they work well.
Old Sep 1, 2010 | 03:28 PM
  #33
Anyone tried the Bosch 13444s yet? They work okay?
