Front tires skip when in reverse
The fix was a "second" front end alignment from another shop. Just remember there are incompetant people everywhere.
I'm 90% sure it has to do with the tire tread/ width of the tire.
I'm just kidding. Have you turned the wheel completely to the stop to see if its anywhere near rubbing. Will it do this on any surface? Like have you made sure its not icy out. I'm 90% sure it has to do with the tire tread/ width of the tire.
If thats not it...Im going to say its a brake binding issue. Have you checked your pads for even wear? Make sure they arent wearing like wedges. If it doesnt matter what angle you have your wheel at, or how fast you are going, something has to be binding you up.
Have you jacked up a corner and tried spinning the wheels by hand? To make sure the wheel bearings arent going bad?
It'd be cool if you could get a video of it happening. Even cooler if you could find a way to attach the camera under the car to look at the spindle area while reversing.
J.
