Sponsored by: CARiD
Front tires skip when in reverse
Old Mar 31, 2010 | 12:43 PM
  #61
THE SHOP's Avatar
Thats is alot of parts to shotgun have you thought about trying a mechanic shop?
Old Mar 31, 2010 | 01:17 PM
  #62
99monguse's Avatar
Thats what I was thinking...before I blast-out all new parts, I'm getting a qualified opinion first!
Old Mar 31, 2010 | 05:22 PM
  #63
Ryanmgaspard's Avatar
I also had a loose shock bolt where it mounts to the control arm and I think one of the wheel hubs were bad. I saw what looked like metal to metal on the back of my rim just slightly though.
Old Mar 31, 2010 | 05:27 PM
  #64
THE SHOP's Avatar
IT WOULD TAKE A TECH 10 MINUTES TO CHECK MAJORITY OF YOUR FRONT END, jack up the front get a pry bar under the tire and try to pick it up it should be stiff if it clicks up and down check hub and ball joints the move tire left to right with your hands and see if there is any slack to check tie rods and linkage.
Old Apr 3, 2010 | 03:00 AM
  #65
joecar's Avatar
When you assembled the spring/damper, did you compress the spring sufficiently so that you weren't torquing the nut down against the spring...?
  #66
joecar's Avatar
This happens with the before and after alignment numbers...?
The before numbers show a lot of toe.
Old Apr 3, 2010 | 08:31 AM
  #67
Yes, the springs are seated correctly. I think it was a combination of bad bushings and loose parts.
