Sponsored by: CARiD
loud knocking coming from rear?
Old Jan 17, 2010 | 02:24 AM
franksaltz28's Avatar
Default loud knocking coming from rear?
Today my car started making a loud knocking noise when the car is costing, or at a steady speed. If im speeding up or using the brakes its fine. The noise changes speeds depending on the cars speed. I have no idea what this could be, but the whole car shakes while this is happening. What do you guys think my problem is?
Old Jan 17, 2010 | 05:41 AM
7th Darkness's Avatar
Any vibration in the pedals?
Wheel alignment, torque arm mount, torque converter, bushings, joints......
What where you doing before it happened?
Old Jan 17, 2010 | 07:18 AM
Armageddon's Avatar
...with cheese.
Are you confident in your rear-end? I noticed it's been replaced. It's more than likely that the noise/vibration would happen 100% of the time if it was your rear though.
Old Jan 17, 2010 | 12:04 PM
I dont think its the rear end. i think it has something to do with the brakes. It doesnt happen when im using the brakes, and the noise goes along with the tires.
I didnt really do anything bad to triger it. i was just driving about 60mph and when i started to coast to a stop it started happining.
Old Jan 17, 2010 | 12:17 PM
Blackhawk777's Avatar
That's your axles shifting slightly. If you have a C clip setup they do that occasionally. Also, what carrier do you have?
Old Jan 18, 2010 | 02:39 AM
Did a walk aroumd to see if i could find anything wrong, and to my suprise the rear driverside rim had only one lug that was tight.
Well im just glad that was my only problem.
Old Jan 18, 2010 | 12:29 PM
Old Jan 18, 2010 | 03:06 PM
nascarnut08's Avatar
Another WOW! Maybe the lugnuts didn't get tightened the last time they were off. I have also seen that when someone lubricates the studs. Not good to lubricate wheel studs.
Old Jan 19, 2010 | 08:24 PM
yea it was an epic failure on my part, that should have been the first thing i checked. The car has been in shop for the last few months, and was rushed out in the last minute. they probably just didnt get tightened.
