Sponsored by: CARiD
weird oil pressure problem
Old Feb 14, 2010 | 03:24 PM
linebacker50's Avatar
Default weird oil pressure problem
when i start it cold the oil pressure is 40 or so. but when the car is driven a while ( around 30 min ) i notice that at a stop light the pressure is down to somewhere in the nieghborhood of 25 and will literally bounce back and fourth. when i go to accelerate it will increae but only to like 32-34 or so. i changed to oil from 5w-30 to 10w-30. cars got 127 on the clock. the car has never had this problem before and im curious to what would be causing this.
Old Feb 14, 2010 | 09:19 PM
conan's Avatar
Might want to try changing the oil pressure sending unit.
Old Feb 15, 2010 | 07:36 PM
one thing i forgot to mention is that after i changed the oil it didnt do it for 2 weeks or so then it started again.
Old Feb 16, 2010 | 12:16 AM
slayerized6's Avatar
OPSU (oil pressure sending unit)
i had the same problem last month and a new OPSU fixed it right up. check out WS6STORE, for the cheapest, and quicking shippest sponsor selling opsu's
Old Feb 16, 2010 | 01:43 AM
camarolover209's Avatar
yea mine was the sending unit on my V6 havent had a problem with my V8 camaro oil pressure sending unit
Old Feb 16, 2010 | 11:41 AM
ArkBird96's Avatar
my car may be doing the same thing. Don't you have to take the intake manifold off to replace it? ARGH!
Old Feb 16, 2010 | 12:59 PM
can i just go ahead and get a after market oil pressure gauge or will the sending unit screw that up too?
Old Feb 17, 2010 | 04:19 PM
blackz28x07's Avatar
Just get a new OPS, mine was the exact same thing, now when my car is hot it never goes below 35 psi, and is at 55 on the highway.
Old Feb 19, 2010 | 07:55 PM
where can i find a new OPSU? i checked the ws6 store and couldnt find one. also how hard are they to replace?
Old Feb 19, 2010 | 08:37 PM
98 OPSU
http://www.ws6project.com/user_stor/...oducts_id=2193
99-02 OPSU
http://www.ws6project.com/user_stor/...oducts_id=2071
Old Feb 19, 2010 | 08:48 PM
LS6427's Avatar
You have to take the damn intake off.
I was putting my OPSU back on a little while ago with the OPSU "special" socket....and the sumbitch broke. Its so easy to break the bastard.
You have to really concentrate on keeping the socket perfectly straight up and down. Any tilt and you'll snap the black part off the metal nut.
What another **** design by the morons at GM.........
It might be possible to change it with the intake on, maybe. But that would make it all that much harder to get the new one back on without breaking it.
Old Feb 20, 2010 | 09:56 AM
i might just go ahead and get a aftermarket oil pressure gauge and call it good.
Old Feb 20, 2010 | 01:54 PM
Q8-TECH's Avatar
you should use a oil pressure gauge to check the pressure and not the sending unit.
if you are using an oil pressure gauge and have low pressure and high miles it could be a worn pump or more commonly excesive clearance due to bearing wear
