Sponsored by: CARiD
air only blows hot... vac problem ?
Old Feb 23, 2010 | 09:55 AM
3800RS's Avatar
Default air only blows hot... vac problem ?
My 94 3.4, the blend doesnt work on the hvac. It only blows hot. I assume this is vac operated. What should i do ?
Can it be that little check valve in the engine bay ?
Old Feb 23, 2010 | 12:27 PM
fleetmgr's Avatar
Could be that, could be a bad vacuum motor, could be as simple as a hose coming off of the intake.
Start at the intake, and work into the car. My vote would be the hose is off.
Old Feb 23, 2010 | 12:30 PM
stburgpete's Avatar
Check the vac. hoses next to the pcm one of mine broke and did the same thing.
Old Feb 24, 2010 | 01:44 AM
SSdimension's Avatar
Originally Posted by stburgpete
check the vac. Hoses next to the pcm one of mine broke and did the same thing.
+1^^^
Old Feb 24, 2010 | 01:48 AM
nauticalstar2012's Avatar
Yes like everyone already stated... mine did the same thing and it was the small plastic vaccum lines about 3 inches to the right of the pcm.
Old Feb 25, 2010 | 04:49 AM
So what was it????
Old Feb 25, 2010 | 09:30 AM
3800RS's Avatar
sorry been mia. I just took out the hvac and wiggled the cable and it worked.
