Sponsored by: CARiD
Blinkers not working at all
Old Mar 5, 2010 | 09:00 PM
Dark-LS1's Avatar
Default Blinkers not working at all
Hello, I'm hoping I can get some help figuring out what the hell is going on with my car now. I was driving around and they were working great all day. But after about an hour of driving I noticed my blinkers were not working. It's not that a bulb is out because I know it would just stop the blinkers from actually blinking and just freeze on my cluster. This is different. My blinkers don't even light up on my cluster nor do they work front or back. They just simply stoped working in total. My hazards work fine. I checked all fuzes and they all seem fine. Anyone have any recommendations as what it could be? I'm guessing an electrical short. Hoping it's not because I know how expensive that can turn out to be. I'm have one problem after another with this car. I'm about ready to trade it in for a new 2010 SS. Any help is appricated! Thanks in advance
by the way it's a 2000 SS Camaro
Old Mar 5, 2010 | 09:01 PM
waterbug1999's Avatar
low on blinker fluid?
Old Mar 5, 2010 | 09:24 PM
Dark-LS1's Avatar
Blinker fluid? I didn't know such thing existed
Old Mar 5, 2010 | 09:28 PM
check the front running lights.
Old Mar 5, 2010 | 09:57 PM
1996firebirdformula's Avatar
Old Mar 5, 2010 | 11:00 PM
98TAjwh's Avatar
who needs blinkers anyway?
j/k i'd start checking your grounds. sounds like a short
Old Mar 5, 2010 | 11:26 PM
doublea87's Avatar
check the wiring behind the mutifunction switch. mine did something similar a few weeks ago, jiggled the wiring and worked ever since (so far)
Old Mar 5, 2010 | 11:39 PM
fucter's Avatar
what state do you live in, it seems like no ones blinkers work in Arkansas
Old Mar 5, 2010 | 11:43 PM
travismcgillsdaddy's Avatar
its prolly your turn signal switch.
Old Mar 5, 2010 | 11:50 PM
*98TransAm*'s Avatar
hmmm... well there are two flashers... one for your hazards and one for your turn signals..it sounds like your turn signal flasher is bad
Old Mar 6, 2010 | 08:47 AM
Dark-LS1's Avatar
Thanks for all your help, going to try and fix it today.. Hopefully it's just the flasher
Old Mar 6, 2010 | 09:07 AM
Darker Shadow's Avatar
I'd agree with the last two posts: Turn Signal Switch (Contactor) under the dash. Mine acted like the signals were shorting out for about two weeks then Monday I found they didn't work at all. Dropped the under-dash piece and the Switch was right in front of me next to the OBDII port. Hardest part was getting the "christmas tree" pins that hold the plastic piece out :-)
Old Mar 6, 2010 | 11:09 AM
wssix99's Avatar
Save the manuals!
The flasher is a thermal unit, so if its boarderline, it will start to act up the longer you drive and the more it heats up.
The catch is that most chain parts stores won't have the right model - you may have to find a NAPA or something like that.
I'd say its 99% the flasher. If not, its definitely the blinker fluid...
