Sponsored by: CARiD
2000 Camaro Brake light and Blinker problem... Help
Old Mar 6, 2010 | 11:33 AM
frankmarroquin's Avatar
Default 2000 Camaro Brake light and Blinker problem... Help
I dunno where to start... my car is a 2000 Z28 and i got the car like this. I tred replacing the brake light switch already and it didnt help any... checked all the fuses and everything looks fine. what do you guys think i should check now. Oh by the way when i turn on the headlights the rear lights do work dim as they should but bright light for the stop lights dont work. thanks guy id really appreciate you alls input.
Old Mar 7, 2010 | 12:59 PM
wssix99's Avatar
Save the manuals!
So, what is exactly the problem? What does the 3rd brake light do? What to the blinkers do? Do the front blinkers work OK? Do the front marker lights work OK, also?
Old Mar 7, 2010 | 01:29 PM
RA032926's Avatar
sounds like the parking lights are working but the brake lights don't come on when the pedal is pressed... i'd check the bulbs to make sure they are the right ones... i have seen people jam singe element bulbs in the taillights and wonder why the brake lights don't work
Old Mar 9, 2010 | 01:11 PM
Thanks for the info guys but problem solved... fuse kept popping cause one of the wires was shorting out causing the fuse to go bad.
