which of these 3 o2 sensor lengths do I need
DENSO Part # 2344000 11.77" long wire and plug. $48.99
DENSO Part # 2344087 11.81" long wire and plug. $40.00
DENSO Part # 2344025 16.54" long wire and plug $40.00
Also why is the 11.77" wire more than the other 2? Better sensor??
I want to order these asap thanks guys!
If the Densos only last one year you have a different problem thats killing your sensors. Densos are the best 02 sensors ever made. Much better than AC Delco sensors. GM is now using Densos as their own sensors.
, what do I do?? I do not want to run extensions and want to get Densos (by far the best o2s from what I read on this forum). The Best V8 Stories One Small Block at Time
I think Denso makes 18.51" long sensors....I THINK they do. But damn, how short are you with the 16.54"s???
If that doesnt work then I can just get the plug and play extensions from tsp or thunderracing. I thought all the extensions affected o2 performance but it seems only the splicing method can, not the plug and plays. There are some 19" ones on tsp. Thunderracing has 12" which would be perfect, you can also get them in a high temp teflon version for like $2 more but only on the 24" one. You could also get ones actually made by Racetronix and also with the teflon option but these are only available in 24" teflon or not.
hmmmmmmmmm????????????........... lol
