1997 LT1 radiator swap
Hey guys, I don't post here much cause ALL the info i've ever needed has been found useing the search. But i wanted to comment on the exellent advice i got from LS6427. A prompt response and concise info was given with pics too! When i went to the local ac delco parts shop and told them i needed a diff. radiator than stock (for my 02 B4C) they had a sissyfit and said i was going to have problems. What B.S. huh? I trust this site with my cars life and wanted to thank all for the time and effort everyone puts into it. I hav'nt put it in yet allthough i know its a basic type install. I will let let you know when its in.
DO IT!!!!
Cap the extra port off like I did and you're all done.
Most....NOT ALL...but most people that work at auto parts stores are loser, wanna-be racer, idiots that don't know anything about cars. All they know is the computer in front of them and how to order OEM replacement parts. They're just worthless.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
DO IT!!!!
Most....NOT ALL...but most people that work at auto parts stores are loser, wanna-be racer, idiots that know don't know anything about cars. All they know if the computer in front of them and how to order OEM replacement parts. They're just worthless.
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
I said, "so your building a drag car?"
He said, "no man its gonna be my little street sleeper."
I said, "who's gonna build the engine?"
He said, "I'm getting one from a junkyard and my friends gonna clean it up for me."
I said, "just clean it up or machine it and prep it for a big shot like that."
He said, "no man, those Windsors are awesome just the way they are, I'd be going with more nitrous if I was doing a drag car."
This was a couple weeks ago at a PepBoys.
They are truly the morons of our society.
So the radiator finally shipped and its in my room.. I did the cap on the lower drivers side port and i couldent find a old coolent level sensor so i broke down and bought one and now its ready to install. gonna put it in fri morning (no work) I have everything i need and i think the system has natually flushed out since i have filled it about 6 times in one week. (wherever i go i top it of w/ 50/50 orange. and i ran the heater also.) let you know how it goes
I'm assuming he's putting an LT1 rad into an LS1.
Just the cooling surface area is larger...as far as installing an LT1 radiator into an LS1 there is absolutely nothing noticeable. It goes in exactly the same as an LS1 radiator slides in.
I didn't even realize I bought an LT1 radiator. Took it home and put it in and then realized I had that extra port. Capped it and that was it.
Well I finally got a decent day to put the LT1 radiator into my 02 B4C. Man that was an easy swap no sweat whatsoever. I capped the lower port and put a fresh sensor to block off the sensor port (I couldent find an old one to use unfortunatly.) I went by the book and put the car on stands, unhooked everything carefull but did deviate in one small way. I tryed banging on the fan shroud to push it up that 1 inch but it wouldent bugde, acctually the condenser came loose but the shroud and radiator were still stuck together. So i just pulled the entire assembly out the top, took all of 1 minute. unhooked it, put the lower hose on the LT1 rad. and lowered it back in. I figure everyone warns not to touch the cooling fins so coolings not diminished. With the fan shroud attached this was not a concern.
I did carefully knock some dirt from the condenser but it realy wasnt that dirty at all and hooked it all back up. I filled up with 60/40 dexcool and let the air out of the system for about 10 min.
After a quick blast to 6k up on the onramp for a test nothing was leaking! Ausome!
I did find about 1 shots worth of power steering fluid in the drained fluid. it was red in color (kinda fresh looking) What do i do about that?
I have one on mine..I got it when I did the LS Swap..it was free. I never ran the PS Lines to it, just left the fittings there. One day I noticed a little puddle of Coolant under the car and traced it to one of the Fittings. I took them out and put in Brass NPT Plugs..took care of that problem.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
O.K. it was tranny fluid in the radiator not power steering fluid.
So i guess thats not a problem since i have a new radiator musta happened when it started to leak....But... I think i will get rid of the power steering cooler anyway as all it does it heat up the fluid and i have been adding a touch more every 2 weeks so it must be leaking anyways.
Is there a link to capping it all off? I need to divert it from the upper radiator hose someway.
Scroll to the last post. Its a 15-20 min job and costs about $40.00.
https://ls1tech.com/forums/general-m...teering+cooler
