need new window motorrr quick question
You'll be best served by avoiding that site you mentioned. (Its just a web front end for a dealer.) The GM motors are garbage and will just go out on you again. The best bet is to get a Doorman motor from Autozone or wherever. The Doorman design is a new motor (not rebuilt) and is supposed to be sealed better from the elements.
The GM motors (not actually built by "GM") were state of the art in the 1979 GM model cars they were originally designed for. These days, they are not made new and are only available as reman motors. Often times, people will get a reman with a faulty thermal cutoff circuit or a reman wired backwards, etc.
Doorman is one of a few companies that has taken the initiative to do something better with the design and is the most affordable "new" option.
Full disclosure -> I do not have Doormans. I abandoned my OEM design a couple of years ago for the ElectricLife motor/regulator combo. It works better than my motors ever did. (I got my car from the factory.) While on the OEM design, I got a LOT of practice installing and re-installing the window motors. Fortunately, I haven't had to even take off my door panels since changing my motor design.
.. the replacement motors I got at Advance Auto Parts are much better and very fast compared to the GM part .. plus they were only $29 dollars a piece with a life time warranty...Try getting GM to give you another one when it craps out... I replaced both motors 3 1/2 years ago and have not problems since...
