Sponsored by: CARiD
Help,Help
Old Mar 20, 2010 | 01:31 AM
Mrs.Nos's Avatar
Default Help,Help
I just put me ls1 back together again. And the oil press. is only 20 pounds, and will go down after it warm. All i did was mill the heads,polish the crank, and add new bearings,rings,new timing chain.
Old Mar 20, 2010 | 12:48 PM
Mrs.Nos's Avatar
nobody can help me???
Old Mar 20, 2010 | 04:09 PM
Mrs.Nos's Avatar
need some help
Old Mar 20, 2010 | 07:20 PM
2xLS1's Avatar
Did you try the mechanical gauge yet? You have to find out if it is real or just a gauge problem. Try asking in the Gen3 internal forum.
Sharpe's Avatar
Wrong forum.
Moved from Advanced Tech to General Maintenance.
Old Mar 20, 2010 | 07:21 PM
rwb's Avatar
rwb
Check the o ring on your oil pump.
Old Mar 20, 2010 | 07:41 PM
fleetmgr's Avatar
Put a real gauge on it before you do anything else.
Old Mar 20, 2010 | 09:10 PM
Mrs.Nos's Avatar
I put a real gauge in the oil pan peace that you cam unbolt. and it reads the same. Thank you four your help
Old Mar 22, 2010 | 09:18 AM
Mrs.Nos's Avatar
help!!!
Old Mar 22, 2010 | 12:09 PM
fleetmgr's Avatar
If you have that pressure with a real gauge, then you very likely have bearing clearance problems, possibly from the polishing you did.
Did you check the clearances as you assembled it?
Old Mar 22, 2010 | 02:56 PM
NBM-LS1's Avatar
Pull it back apart and look at the o-ring on the pickup to the pump. If you didn't install it correctly and pinched it, it will bleed off pressure.
Old Mar 22, 2010 | 08:54 PM
Mrs.Nos's Avatar
Yes we did. It was in the middle of clearances, that it called for
Old Mar 22, 2010 | 08:55 PM
Mrs.Nos's Avatar
Should I just order a new o-ring and pump? Have you herd of the cam retainer plat gasket leaking past?
Old Mar 23, 2010 | 06:19 PM
rwb's Avatar
rwb
Just put a new o ring on it and be done. I doubt that your pump is gone from this.
Old Mar 24, 2010 | 08:24 AM
slt200mph's Avatar
It is probably your O ring on the oil pump pickup ..replace it and be careful when you do or you will have the same problem again.
Old Mar 24, 2010 | 09:14 AM
Mrs.Nos's Avatar
Ok we will be getting a new pump in. we will asla going to change the cam plate,o-ring and pump. Wish me luck. You can come help if you want
