Sponsored by: CARiD
Changing Spark Plugs
Old Mar 23, 2010 | 11:24 AM
happysem's Avatar
I couldn't get in there, so I made my gf pull 'em out
Old Mar 23, 2010 | 05:44 PM
lemons12's Avatar
Go make me a sammich biatch! And change my plugs while you are at it!
Old Mar 23, 2010 | 05:55 PM
608kZ28's Avatar
i got all mine from the top. no way in hell i was going to get the last one on the passenger side from the bottom.
Old Mar 23, 2010 | 05:57 PM
samson_420's Avatar
Wouldn't that be the life. . . . . .
Old Mar 24, 2010 | 09:17 PM
brownsugar's Avatar
Default Thanks
Thanks for all the feedback. Especially that one about the sammich. I'm gonna try that one this weekend. If that doesn't work, I can always pull the coils!
Old Mar 25, 2010 | 05:03 AM
whytryz28's Avatar
Originally Posted by miller456
oh the joys of deleting the a/c
[IMG]http://i271.photobucket.com/albums/jj136/rgmiller456/nitrous.jpg[IMG]
Oh the joys of having a/c!
Old Mar 25, 2010 | 07:26 AM
miller456's Avatar
thats what i have a daily for that has a/c. Who the hell needs a/c with t-tops
Old Apr 24, 2010 | 02:23 AM
BlakeLan2010's Avatar
+1 for T-Tops!
Old Apr 24, 2010 | 06:53 AM
AFASTYZFR1's Avatar
Just pull passenger side coil packs. I have a/c and can change plugs in 30 min.
Old Apr 24, 2010 | 12:06 PM
eseibel67's Avatar
Originally Posted by 00MaroonZ28
I went thru the bottom. I was tearing up my hand from going thru the top.
The little plastic pins that hold the cowl seal down are what's chewing up the back of your right hand.
Pop them out before you start the plug change.
Old Apr 24, 2010 | 12:52 PM
tuffluck's Avatar
it actually isn't that difficult. the first time is the worst because they are put so tightly in the car by the factory. if you remove the coil packs--and you should--it makes everything much easier. the far rear bolt on the coil pack is an absolute PITA, but once you get it off, don't ever put it back on. the first time i changed my plugs it took a few hours. the 2nd time i did it, for whatever reason i decided to do it in 20 degree weather outside, and i finished in under an hour.
Old Apr 25, 2010 | 09:36 PM
  #32
Grimes's Avatar
#8 is definitely easier from the bottom of the car, reaching up. It's important to have a small ratchet too.
Old Apr 26, 2010 | 02:29 AM
  #33
sjsingle1's Avatar
if you do it from underneath for num 8.............take off that heat sheild on the exhuast.......it tore my arm up
