Sponsored by: CARiD
ls1 steering columns
Old Apr 2, 2010 | 01:29 PM
brunz21's Avatar
Default ls1 steering columns
Hey does anyone know if there is a difference in steering columns from an f-body with a six speed trans vs. an automatic? im looking for a column for my 98 ss, along with the matching bcm. If anyone has one they'd like to get rid of, let me know. Thanks
Old Apr 2, 2010 | 07:16 PM
bigj2717's Avatar
The only difference is the key cylinder.
Old Apr 3, 2010 | 12:46 AM
brunz21's Avatar
so is it just as easy as swapping the columns or do i need to swap lock cylinders as well?
Old Apr 3, 2010 | 12:50 AM
bigj2717's Avatar
The way I did it was I put the other column in my car and used my key cylinder so I didn't have any problems with the vats. But either way you need the right key cylinder for your car
Old Apr 3, 2010 | 01:09 PM
209ryder's Avatar
Do you guys have any tricks or pics of pulling the colums out ???
Old Apr 3, 2010 | 08:17 PM
Spartan7's Avatar
Or just get a new key cut for the new column. The cylinder doesn't read the pellet, the BCM does.
Old Apr 3, 2010 | 11:59 PM
wssix99's Avatar
Save the manuals!
What about the interlock that captures the key until the car is in park on an automatic. Is this mechanism installed in the manual column?
Old Apr 4, 2010 | 05:03 PM
slvr98camaro's Avatar
no, the manuals have a button you press to release the key.
Old Apr 5, 2010 | 09:15 AM
brunz21's Avatar
can i remove the ignition set from my manual column and put it in an auto column without having problems with the interlock? my car is a manual, but i found an auto column with bcm for cheap. also will an 00 column plug directly into my 99 body?
