Sponsored by: CARiD
MASSIVE oil leak.. Help!!
Old Apr 5, 2010 | 07:19 PM
pj4553's Avatar
Default MASSIVE oil leak.. Help!!
I've only had the car for about a month. When I bought it from a friend it had a small oil leak that would leave a spot about the size of a silver dollar. I didn't think it was a big deal since I planned on getting the bottom end freshened up from Futral and installing a head and cam package later in the year. Well, today I noticed a line of oil leading up to where I was parked that I had never seen before. I looked under the car and saw the oil was dripping down the oil filter. I started it up and looked again and it was just running down the filter and onto the ground on a steady stream . WTF? Where do you think it's coming from and why did it get worse? I need help!
Old Apr 5, 2010 | 07:24 PM
Squirts11's Avatar
It sounds like either the filter is pinching its rubber seal, or the pan gasket has gone bad.
Old Apr 5, 2010 | 07:54 PM
HotSilverBird's Avatar
naaa look right above the filter you will see two small bolts that hold a small cover on. Tighten those bolts, THEY ARE LOOSE!
Old Apr 5, 2010 | 10:19 PM
pj4553's Avatar
I hope it's just that simple.
Old Apr 5, 2010 | 11:49 PM
ArcticMissile's Avatar
+1
Old Apr 6, 2010 | 07:35 AM
bjamick's Avatar
yep sounds as if those 2 bolts have vibrated loose, the oil filter is not on tight, or the oil filter gasket is missing, or the previous oil filter gasket is in place along with the new gasket on the new filter, or the oil pan gasket. I think it has something to do with the oil filter probably seeing as that's where it's leaking at.
Old Apr 6, 2010 | 08:17 AM
THE SHOP's Avatar
he listed it all.
Old Apr 8, 2010 | 04:45 PM
pj4553's Avatar
Think I located the problem. The oil filter is smashed. I must have bottomed out somewhere. There is oil everywhere. I'll post up pics in just a sec..
Old Apr 8, 2010 | 05:08 PM
pj4553's Avatar
It's leaking from where I circled in red. Guess I'll be changing the oil tomorrow LOL. Also, what is the part circled in yellow and what does it do?
Old Apr 8, 2010 | 09:12 PM
98pontiac's Avatar
what the hell kind of oil filter is that???
Old Apr 8, 2010 | 10:12 PM
TXZ28LS1's Avatar
That sucks.. my car leaks oil a bit also just like you described!! My car sits there for weeks and notice little drips. My buddy looked and said it was the oil pan gasket..
Old Apr 8, 2010 | 10:14 PM
Cameano's Avatar
cheap.
Old Apr 8, 2010 | 10:19 PM
pj4553's Avatar
IDK.. Ported and polished LS10 filter I believe.
Yea. It was on the car when I got it. I just went and picked up a new one a little while ago. I was almost wondering if it is the correct filter
Old Apr 9, 2010 | 08:08 AM
THE SHOP's Avatar
Isn't that a K&n Filter?
Old Apr 9, 2010 | 09:37 AM
pj4553's Avatar
No, I dont think so.
Old Apr 9, 2010 | 10:05 AM
THE SHOP's Avatar
You have not just pulled it off? And I was pretty sure it was....
Old Apr 9, 2010 | 10:06 AM
THE SHOP's Avatar
http://www.knfilters.com/oilfilter.htm
Old Apr 9, 2010 | 10:52 AM
pj4553's Avatar
I'll let you know in a bit. I'm headed to fedex to ship some parts and then I'm coming home to change the oil in the car.
Old Apr 9, 2010 | 02:26 PM
pj4553's Avatar
Yep you were right. It was a K and N. This is why I was gushing oil LOL. Now I gotta clean the mess under the car
Old Apr 9, 2010 | 02:53 PM
udienow's Avatar
This is why people don't like to run those bigger filters. I actually stay away from K&N because of that bolt on the bottom...
At least I assume thats the bigger filter, otherwise idk how the filter got bottomed out.
