Can't track down the *ping* noise. Feedback please!!
So I keep getting a ping noise coming from the trans/drive shaft area with a change in load(accel and decel).
Things I have replaced:
Trans Mount(poly)
Torque arm mount(poly)
Transmission(from 4l60e to T56)
Read end(from LT1 to LS1)
Drive shaft u joints(spicer)
Also had the shaft checked for balance.
Now, the car is lowered and has LCA relocation brackets(lowest setting). Upon harder acceleration I can feel a strange vibration.. but it is fine under normal load. My Y-pipe is clear of the frame so I know it's not that. Is it possible the drive shaft yoke is bad somehow? I have a small leak coming from my pinion seal with both auto and manual transmissions. Previous owner of the T56 claims it never leaked a drop and I believe him. I would really just like to stop replacing parts and learn from someone else who solved this same problem. Any feedback what so ever is greatly appreciated. Thank you!!
Trans Mount(poly)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
have you lifted your car and checked for fresh marks? thats what i would do. put her up on a lift, and that would be the best that i could do. as for the vibration it sounds to me like maybe an off balanced torque converter tho i dont know how that could have possibly happened. the yoke should be just fine i havent seen too many chevy's where the yoke wasnt able to fit into another chevy tranny. and when i say i havent seen to many i mean i have never see that problem.. one last thing i can offer is that it could be the angle of your drive shaft. I hope this helps you at all. and i thought even if i am wrong.. at least i put something up here to help you out.
Late
Late
