Sponsored by: CARiD
The Z28 is making some noise...
Old Apr 17, 2010 | 03:55 PM
bene's Avatar
Trunion King
Default The Z28 is making some noise...
It sounds like an exhaust leak, tapping or ticking but there isn't any leak anywhere. The sound is coming from the driver side area. I opened the valve cover on that side to see if there is any valve/spring/rocker broken or loose. All is good. The car is running like it should, not throwing any codes, no stalling issues, oil pressure is great. So I'm baffled on this one.
It starts making the noise around 1.5K rpm and become more pronounce on 2K and goes faster (ticking or tapping). It doesn't get any louder though.
WTF?!? Any ideas guys?
Old Apr 17, 2010 | 05:49 PM
fleetmgr's Avatar
Maybe some lifter noise? Stethoscope time.
Old Apr 18, 2010 | 03:35 AM
bene's Avatar
Trunion King
How is the stesthoscope work? The engine itself is loud enough already?
Old Apr 18, 2010 | 08:04 PM
itsnickyo's Avatar
haha you probe with it cause when you put it on what ever is making the noise you will be able to hear were its coming from
Old Apr 20, 2010 | 11:59 AM
bene's Avatar
Trunion King
Here is a video of that weird noise...
http://www.youtube.com/watch?v=4l9hqWZGk-0
Old May 6, 2010 | 09:55 AM
w06gto's Avatar
I have the same noise i thought loose rocker? did you find out what it was?
Old May 6, 2010 | 10:51 AM
twitchtwice's Avatar
sounds like a header gasket leak almost. weird.
Old May 31, 2010 | 02:31 PM
MachoCamacho's Avatar
Anymore opinions or solutions to this? Sounds like the exact scenario I've run into.
Old Jun 1, 2010 | 09:10 PM
Blackhawk777's Avatar
Did you check to see if your spark plugs were tight? Kindof an odd reason why, but if there's one loose, it sounds ALOT like valvetrain nose. Mine did it about 2 months ago.
Old Jun 1, 2010 | 09:15 PM
camaro981289's Avatar
My car does that too...friend of mine that works for GM said its normal in LS motors...my '00 Z71 did the same thing.
Old Jun 1, 2010 | 09:19 PM
LaBLKv6Z's Avatar
I have a similar noise but I think my drivers side header gasket maybe the culprit.
