Permanent fix to bent fender tab problem
Has anyone done a write up on how to fix the bent front fender tab issue permanently on a 4th GEN Camaro. I know bending it back will work, but can still happen again if someone is careless. After this happening several times the tabs will break and the fenders will crack. Several folks have done a flush mounted fix and that is what I am leaning towards and others have done this.
Mine is a 2002 Z28.
Thanks - Mike Jones
Mine is a 2002 Z28.
Thanks - Mike Jones
has anyone done a write up on how to fix the bent front fender tab issue permanently on a 4th gen camaro. I know bending it back will work, but can still happen again if someone is careless. After this happening several times the tabs will break and the fenders will crack. Several folks have done a flush mounted fix and that is what i am leaning towards and others have done this.
Mine is a 2002 z28.
Thanks - mike jones
Mine is a 2002 z28.
Thanks - mike jones
The permanent fix is to either work on the car yourself or take it to someone who knows what the f%ck they're doing and dealers don't count! When I bought my SS brand new and took it in for the 1st oil change the dumbass tech lifted the car using the tabs...thinking they were pinchweld-liftpoints. I was going to have the lift points marked with big bright "LIFT HERE DUMB-***" in yellow writing and "DON'T LIFT HERE **** HEAD" in red writing
![Stupid](https://ls1tech.com/forums/images/smilies2/stupid.gif)
![Werd](https://ls1tech.com/forums/images/smilies2/werd.gif)
