Sponsored by: CARiD
Drowsy Engine During Idle
Old May 3, 2010 | 10:32 PM
Chronicle's Avatar
Default Drowsy Engine During Idle
Okay, I've had this issue on and off for about a year now. What happens is when I'm coasting or at a stop, the engine's idle speed will dip down to the 500 range, jump back up to about 1500, and fall back to my normal idle. Only once where the dip was strong enough that the engine just died on me, but I was able to just turn it back on.
Old May 6, 2010 | 12:22 AM
Chronicle's Avatar
Anyone?
Old May 6, 2010 | 07:25 AM
91RS383's Avatar
What have you modified? Anything big happen about a year ago when it started?
Have you cleaned the IAC valve?
Old May 6, 2010 | 08:17 AM
Chronicle's Avatar
It's basically stock, all it has is a lid and a catback. No, I haven't cleaned the IAC valve. If I can make it to the shop today I'll clean it off and see if it helps. Thanks.
