Sponsored by: CARiD
AC issue
Old May 4, 2010 | 11:20 AM
01ssreda4's Avatar
Default AC issue
Seems pretty simple, after a long drive, 1fstz and I get out of his 90 hardbody PU and hear a hissing sound, sounds like a tire is going flat. Turns out one of the ac line fittings has apparently come loose. So we snug it up and the AC is blowing hot. It hadnt't been doing great the whole day though come to think about it. So I say no biggie we can throw a can in and it should be all good. We get some freon the next day and go to stick it in, gauge is showing the system at 0 psi, and we cant get it to take in the system. System is so low now the compressor isnt even coming on. But with 110 psi in the freon can it wont go into the ac system. Changed shrader valves to a know good one and still nothing. Tried the freon can on another car and it took. Ideas?
Do I need to hot wire the compressor to get it to take the charge?
Old May 4, 2010 | 11:23 AM
fleetmgr's Avatar
That'll do it.
Old May 4, 2010 | 12:43 PM
1FST-Z's Avatar
So is that to say that in order for the system to accept the can of coolant, the compressor has to be running? If so, how the hell would you get the compressor to kick on and make it happen... other than ghetto rigging a jumper??
Old May 4, 2010 | 12:46 PM
01ssreda4's Avatar
Since when is a jumper wire ghetto?? Its a fully functional device solving a very temporary issue. Its ingenious
Old May 4, 2010 | 12:48 PM
1FST-Z's Avatar
Old May 4, 2010 | 01:23 PM
fleetmgr's Avatar
If you have a laptop, software and cable you can command engage the clutch. Ten cents worth of wire makes more sense to me.
Old May 4, 2010 | 01:31 PM
1FST-Z's Avatar
Point well made, sir
